Deletes an entry from the snmpNotifyTable.
| hex_notify_name | Specifies the notify name to add. The value is to be supplied as a colon separated string of hex octets. |
| notify_name | Specifies the notify name to add in ASCII format. |
| all-non-defaults | Specifies that all non-default (non-permanent) notifications are to be deleted. |
N/A.
Use this command to delete an entry from the snmpNotifyTable. When a notification is to be sent, this table is examined. For the target addresses that have been associated with the tags present in the table, notifications will be sent, based on the filters also associated with the target addresses.
The following command removes the N1 entry from the table:
configure snmpv3 delete notify N1
The hex_notify_name parameter was added in ExtremeXOS 11.0.
